bleach/softener dispenser does not fill with water
The bleach/softener dispenser won’t fill with water. It appears all hoses are connntected and I visibly inspected that all ports are open. I suspect the problem is the dispensing valve or the control panel. Is there a test I can do to isolate the problem.
You should find a tech sheet inside the console. It shows you how to put the machine into a self-diagnostic mode.
