blinking "rinse only" and possible stuck buttons?
Hello, I have a "rinse only" light blinking. If I push cancel there will be two bars showing on the LED but if I push again they will disappear. The "rinse only" continues to blink.
When I cut power to the unit, sometimes it will start briefly then shut down and display the blinking light again only.
Also, it seems like the far left buttons, "antibacterial" and "pots and pans" don’t seem to have a "click" sound like the other buttons. These buttons are not used so i’m wondering if/how they are stuck.
If I open and close the door several times quickly, all the lights light up and the LED numbers until or unless I push cancel.
I have tested the door switch and thermal fuse and they check out ok.
Any recommendations would be greatly appreciated. Thank you.
