First the heating element went bad replaced it then after replacing that the thermal fuse blown after one load then i replaced it with new one and it lasted three loads then i replaced the cutoff thermal with the kit WPL 279816 part no. and replaced the thermal fuse with another new one and it blew out the fuse again. I HOPE SOMEONE CAN HELP ME WITH WHAT I NEED TO DO TO FIX THIS. THANK YOU
Related topics
Dryer is blowing thermal fuses | 5 | 7123 | January 9, 2009 | |
Thermal Fuse Blows | 1 | 1297 | July 5, 2013 | |
dryer thermal fuse blowing | 1 | 1992 | July 20, 2011 | |
dryer blowing thermal fuse on heating element | 7 | 11450 | May 25, 2011 | |
Are cheap thermal fuses defective | 1 | 625 | January 3, 2015 |
