Bosch Dishwasher no power
We have a Bosch SHX57C Dishwasher that we bought at Sears. Worked perfectly until my wife tried to use it yesterday. When she opened the door to start the unit, there were no lights on the control panel or the display, and the unit would not start or run. Also, there was a little bit of water left in the bottom of the unit, so it apparently did not drain completely during its last cycle. I checked the power at the wall plug under the sink and the power is on. I got my multimeter, took off the front panel, and there is power to the on/off switch and it works correctly when operated. I checked the door switch with the multimeter and it seems to be working correctly as well. Hating to think the control module was bad, I opened it up and could see no evidence of burned components or bad solder points. Are there any other switches that could be malfunctioning? Any other ideas?
