Bosch shu66c02uc/14 wont fil
My bosch shu66c02uc/14 wont fill with water… here is what i know and what i have done. I can force it to drain by manually pushing the drain switch. it comes on and i think the CIrc motor is on … but no water is coming in. Do i need to check more or is the water inlet valve bad.
any help or suggestions would be greatly appreciated.
UPDDATE!
I turn it on. It fills drains…seems to heat… do several cycles drains again… counts down to 1 then seems to hang there does not shut off.
Heres what I observed… i can open the door during wash cycle and the propeller seems like it was NOT turning. like the circulation motor and pump is not working properly. Maybe the the motor on but pump not working or its weak. Seems like i can hear the circ motor.
but the count down to 1 and hanging there has me puzzled too.
