Bosch sprayer channel clip spot weld failed on back wall
My Bosch sprayer channel clip has come off the back wall. It was factory spot welded on. I’m trying to see what would be the best approach. I’m a decent welder but not proficient. I’d hate to burn a hole through. I might be better off using my tig rather my mig. Then I thought of using a stainless screw with a rubber type washer for a seal. Any thoughts?
Billymons, unfortunately, we would not be able to recommend a procedure for repairing the channel clip as it is far to easy for damage to occur and cause a leak.
