I have Bosch WFK2401, when I press start, it start to add water then I hear click but nothing happened. No error code present, also I can see the numbers going down the same way it is working (start from 65 and down). Do you know what could be the problem ?
Hi.
It could be control board (witch is no longer available), door lock, motor, wire harness between the motor and control board.Try the plugs first.
Then you should run the diagnostic test.
Check the attachment.
Simon.
Hi
Thank you for the doc. I run the test and I got the error 08 Motor won’t run.
What can I do to fix it ? what could be the Problem ?
Hi
Hi.
Here is the corrective actions list.
Simon.
