I replaced the boot seal in the door because water was trickling out behind the base of the door and running down the lower front part of the washer. Still have the same problem. Clamps are installed properly and there are now wrinkles or issue with the boot seal itself. It’s OE equipment. Any suggestions on next steps? Door is aligned properly and seems to be snug against the machine.
Related topics
Door leak after replacing door seal boot | 4 | 819 | March 8, 2017 | |
bosch WFMC gasket pt#0066747 door seal replacement | 1 | 260 | August 22, 2018 | |
Washing machine Bosch leaks water | 1 | 1892 | August 20, 2010 | |
GE front load leak | 0 | 1708 | April 29, 2008 | |
Bosch d/w door leak | 1 | 1001 | October 10, 2010 |
