bosch
Hello,
my dishwasher has a heating issue due to the standard self test I ran on the unit. This model was the one with the 10A relay that some people on this forum upgraded to a 12A. I can see the burn mark from the old relay on the board.
I ordered the part at digi-key and just before I was about to install it (double checking the old part specs in the board) I noticed that I must have sourced the wrong part by mistake. My new relay from digikey is 6V, where the part to be replaced is 12V.
The question i have is, which is the appropriate upgraded 12A relay to use for this? finding the right part on digikey is daunting if you don’t know what you are looking for. Is this the correct part after all?
the original part on the OEM relay on my board is is this, a AJS1311
[T7CS5D-06 TE Connectivity | PB336-ND | DigiKey](http://www.alldatasheet.com/datasheet-pdf/pdf/98638/NAIS/JS1-12V.html"]JS1-12V Datasheet(PDF) - Nais(Matsushita Electric Works)[/URL]
http://www.digikey.com/product-detail/en/JS1-12V-F/255-2080-ND/648567
the one i ordered from digikey was this
[URL="http://www.digikey.ca/product-detail/en/T7CS5D-06/PB336-ND/262603)
thanks for your help in advance. could anyone in the know please point me to the correct part?
please does anyone have an answer for this?
