bravos mvwb450 LF
Washer would intermittently, like every other month, give the LF error which I have read is long flow. Yesterday it became persistent. The washer cycle (any cycle, any temp) will start, I hear some water spray but when the fill cycle should actually start, the water inlet valves hum and eventually I get the LF error. Flow thru the hoses is good. Screens are clean. If I pull the ac plug for a few hours, the washer will run for about 10-15 minutes but then give the LF error when it is time to rinse.
Considering the water valve assy and/or control board, leaning toward the board.
Any thoughts?
I’m thinking the main valves work but one or all of the other valves aren’t opening. Is there a sequence that the other valves are supposed to open.
Would you have a link to a service manual for this model washer?
Thank you, Kevin
