broiling only in oven
:eek: My oven will come on in broil only–the lower element doesn’t come on at all. What do I need to look for to repair this problem?
Hi.
You will have to do some testing, using the multimeter.
If you fill comfortable doing that follow the directions.
Unplug the range.
With the range out, remove the rear panel to get the access to the elements from the back.
Turn the oven to Bake and check if there 230VAC at the bake element contacts.
If you have the 230VAC and the element doesn’t work - replace it.
The bake element 74010750
If no 230VAC - replace the control board 12001628
Here are he breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45427
Thank you. Post the results.
Simon
