Broils instead of bakes
When the bake button is pressed the broiler comes on instead of the bake element. Element reads good with a meter. What else besides the clock/timer control modgule could it be?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FEF366EMC
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441437en.pdf
Do you know for sure that this is not how it always worked or did you just notice this and felt something was wrong?
The reason I ask is that it is normal for stoves to switch back and forth between the bake and broil elements when in pre-heat and bake.
Also are there any other symptoms of a problem?
If the bake never comes on then the control board would be at the top of the list. I would unplug the unit and check the wiring from the board to the bake element just to be sure it is OK.
