Broken pin tab on ice dispenser door
So the plastic tab that holds the pin/spring (right side) of the ice chute flap/door is broken. Problem is, it appears to be part of the main housing of the dispenser and I can find every part for the dispenser except the housing. What do?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ED5VHEXVB00
I think the part you want is item 1 in section 08.
It does not show a part number so it would be best to call a parts representative at AppliancePartsPros they have more knowledge and access to part info than what is available on the web site.
— Begin quote from denman;869298
Parts for Whirlpool ED5VHEXVB00 Refrigerator - AppliancePartsPros.com
Exactly my issue. After more digging it seems that not only is the part # not available, it considered a not serviceable part. I was able to find an ice chute door kit with an extra aluminum bracket to replace the broken plastic tab of the main housing.
http://www.appliancepartspros.com/whirlpool-door-chute-8201756-ap3872692.html
