brum slowly fills with water
Hi, I’ve noticed that that drum slowly fills with water when not in use. An inch of water over night! I have to set the washer to drain/spin to get rid of the water. Is there an easy fix for this issue?
the water inlet valve is bad. the valve "seat" is bad and not closing all the way allowing water to seap by. new valve, no more problem
