Built-in Electric Convection oven won't heat
After Running A Clean Cycle My Model kebc107kss0 Oven Will Not Heat Everything Else Works. Does A Thermostat Need To Be Replaced And How?
Thanks,
Cwicky
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265371
Have you tried flipping the breaker off/on slowly a couple times?
Odds are that you blew the thermal fuse (Item 37 in Section 4).
Click on the parts picture for more info and a Q&A section.
