Burner doesn't work & hot indicator light stays on
[SIZE=3]The left rear burner does not heat up (smooth cooktop) & the hot surface indicator light stays on. Help!:frowning: [/SIZE]
Someone would need to confirm if power was getting to the element or not. Power there but not working = defective element (or defective element limiter which is not available separately).
LINK > http://www.appliance411.com/data.php?ap=AP4008687
That is controlled by the element limiter. The indicator staying on even when not hot would point to a problem in the element limiter… which might also be responsible for the heating problem.
JMO
Dan O.
http://www.appliance411.com/parts/?ref411=Maytag+Range*The Appliance Information Site*
=D~~~~~~
