Had a load of clothes in the dryer last week that never dried. I tested continuity on flame sensor, igniter, and the thermostats and I’m getting a continuity reading from everything. I haven’t been able to find a service manual so that I can actually test for proper resistance or receiving proper voltage at the gas solenoids or on the resistors built into the thermostats. No idea if there’s a thermal fuse for this model either.
The igniter will light, followed shortly by the burner lighting as it should. I thought it worked fine after I put it back together, but apparently it still isn’t coming back on again after the initial shutoff.
Any help on this would be appreciated. I’m frustrated with it; wife wants to buy new and I know fixing is going to be a lot cheaper. Of course, it couldn’t just be a simple "oh, look, the igniter fell apart" fix! lol
