The right front burner would not always come on, when it did the flame was irregular and flames would come out of the air opening in the connecting tube. We replaced both the back and front burner, the back burner works fine, but the front burner still has the problem. What to do?
— Begin quote from twarshavsky;284022
You should check the oriface (brass fitting that the burner tube encloses)for clogs, dirt, grease etc.
If thats proper, you will need to replace the burner valve .
[part]AP4284817[/part]
Good Luck,
We did what you suggested and it worked. My husband still doesn’t believe it was that simple. Thanks alot.
— Begin quote from twarshavsky;285539
We’re glad it was that simple,
and happy that you’re happy
You’re welcome,
