burnt wire that connects to the power block
The dryer works but does not heat. After inspecting I found one wire on the power cord had burned and broke. Replaced the cord with a new one only to hear a popping sound and the smell of burnt wire. My question is what wires connect directly to the power block so I can replace that item and prevent damage or a fire.Wires don’t just over heat an cause a fuse to pop.
[SIZE="4"]DUPLICATE[/SIZE]
Please see the following
http://forum.appliancepartspros.com/dryer-repair/88881-burnt-wire-connects-power-block.html
