[SIZE=5]my dryer ,power cord ,mealted away ,this is y dry wouldnt work. my ? is where can i buy a new ,block terminal ,and a new power cord , I need info ,on how to wire the block terminal to the dry power cord.[/SIZE]
The terminal block (AP3425411) comes as a kit with new connectors and screws, so remove the old parts and install the new parts. The dryer cord can be purchased at most hardware stores and the type depends on the cord you are using. Remove it and take it with you to ensure you get the correct type and size. Just make sure you remove all the damaged wire and tighten the screws to prevent it from happening again.
