Cabrio Electric Dryer Low Heat
Hello. I have a Whirlpool Cabrio electric dryer model WED6400SW1 that is putting out low heat regardless of the control settings. I checked the heat duct with a infrared thermometer and it’s reading between 120-125 degrees F. Internal drum temprature is only 85 degrees F. What is the troubleshooting process? Thank you.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED6400SW1
And here is a service manual
http://appliancedigest.com/index.php?/files/file/305-whirlpool-8178584-cabrio-dryer-service-manual/
You will have to join the site to get the manual but it is a good site for info for the appliance DIYer.
Probably would not be a bad idea to check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Try running the diagnostics to see if an error comes up.
Check the heating coil.
Unplug the unit and remove both wires from the heating coil.
Then measure it with a meter, should be around 10 ohms.
Then measure from each connector to the case, both should be infinite ohms (open).
If not it could be the coil is grounded and is causing problems.
If OK
Check both thermostats with a meter, see the tech sheet.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Sitting on the blower housing is a part called a thermisiter. It’s job is to measure temperature. I have a feeling that will be your issue. The part # is 8577274. Tom http://www.applianceeducator.com
— Begin quote from kayakcrzy;379602
Sitting on the blower housing is a part called a thermisiter. It’s job is to measure temperature. I have a feeling that will be your issue. The part # is 8577274. Tom ApplianceEducator.com
Thank you Sir. Any way to test it?
— Begin quote from denman;379575
[Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED6400SW1"]Replacement parts for WHIRLPOOL WED6400SW1 29`` ELECTRIC DRYER | AppliancePartsPros.com[/URL]
[URL="http://appliancedigest.com/index.php?/files/file/305-whirlpool-8178584-cabrio-dryer-service-manual/)
If OK
If OK
If OK
Wow… Thank you for the great reply and information. I was asking myself how to run the diagnostic, then I saw you attached the tech sheet. It may be a couple of days before I get to work on it (again, it’s drying lukewarm), but will let everyone know what the final problem was. Thanks again.
Finally got the parts and repaired today. Dual heating element was burned up pretty bad and falling apart. EXPENSIVE ($125). Also replaced high limit switch and both thermisiters. All is well for now. Thanks again for the tech info and advice.
You are welcome, glad to hear you are up and running.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
