[SIZE=3]We are constantly having unbalanced load issues with thewasher no mater the size of the load, big or small, it doesn’t matter. I pulled the unit apart to the point that I lifted the basket out of the washer basin; it was here I discovered water internal to the basket that I can’t drain out no matter which way I turn or shake the basket. I want to confirm that this water does not belong and I want to know if drilling relief holes (and leaving them thereduring future wash cycles) into the bottom of the basket will not screw the basket up even more. Or maybe there is another way to correct our problem. [/SIZE]
i put a post out here yesterday saying suggesting to drill holes in the basket to let out the water htat is trapped inside. THAT INFO WAS ERRONEOUS and based on bad information I received from other repair sources. SORRY. I since found out that the water that is inside the basket assembly IS SUPPOSED TO BE THERE and it is there to help balance the basket during spin. If the basket is out of balance during spin, it is most likely caused by weakened suspension system parts.
