Replaced suspension springs and upper and lower suspension pads. Washer still hops across the floor during spin. Does anyone know how much liquid is inside the basket balance ring??? I’m thinking it might be that.
Not likely on the balance ring since it’s a sealed unit. Sounds like something didn’t get put back on correctly or you’re washing small heavy loads?
Reassembled correctly. However…
During disassembly, noticed the water in the basket balance ring and was unaware that it was supposed to be there, so drained it. Now knowing that it should be there, I will replace the water if I knew how much to put in.
You could just wing it with a couple of Pepsi cans full of water, or weigh a new one at a parts house and add accordingly. If mine was off I’d weigh it for you.
All set…
Added saline solution until about 3/4 full. Worked like a charm
