In both Normal and Quick wash, the machine seems to go thru the wash cycle fine but once it gets to rinse it goes into kindof a "dance". Water comes into the the tub, the tub moves slowly one direction, then the other, the drain pump kicks on. Each of these actions may only last a second or two. It seems lost and irratic. At times it will stay on 20 minutes remaining and never count down and other times it will take 4 minutes to go from 20 remaining down to 19 remaining.
I have had the pump out and all looks clear. I also removed the agitator and found a couple of quarters.
For mine it was actually the Machine Control Board. I found someone with the exact problem on **************************.com. AppliancePartsPro did have the lowest price though. Good luck.
Rod
Thanks Rod…that is the kind of help I was hoping for. I will order that board and see what happens. I will get back to you with the results.
