I have a kenmore calypso washing machine. Recently it went through a wash cycle and then got stuck in the rinse cycle. It did not give any error codes. It still had the time going down, but it went extremely slow. Now it will not even make it out of the wash cycle. The machine will start to spin and then stops. It keeps doing this until I stop the machine. Could this be one of the control boards? Please let me know if you need any additional information.
If you will post a model number we should be able to link you to a tech sheet or service manual that will show you how to put it in diagnostic mode. Of course, if the main board is bad the diagnostics may also not work, but let’s see.
I have the same issue. Diags run fine. Hesitates and will resolve if left off. Replaced motor control board but issue persists. Help??!?
