Hi the oven started beeping and the code F1 was flashing ,I tried a breaker reset and It started beeping and flashing again…If it is the control panel ? do you include instructions on replacing it with the part?
great website,thanks John:cool:
Most likely the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer and is no longer available. Check PCBR.BIZ if they can repair the old control board.
