Kenmore range
During the night a loud beeping began and the oven showed a F1 code. I do not have a manual and I don’t know what is wrong. We have turned off the breaker to the stove to stop the beeping. Can you help.
— Begin quote from GlennaJoan;279178
Glenna,
The F1 code for your range, would indicate a stuck button or bad ERC(clock).
Did you notice or check for a stuck or loose selector button on the control panel ?
Make sure none are loose, and operate properly(in and out when pressed).
Check and make sure the lens and button assembly are not loose in the control panel.
[part]AP2029853[/part]
If you’re buttons operate properly and nothing is loose,
You would most likely have a failed circuit in the ERC (clock).
[part]AP2022859[/part]
Good Luck,
