Code F2E1
oven shuts off and code F2E1 appears in clock ??? Any ideas:)
Most likely the problem is a bad keypad. If you need the correct part number, post the Complete model number of the range and the color of the key pad.
— Begin quote from captnTomTomTom;295847
Captn Tom,
Like Gene stated,
You most likely have a bad touchpad assembly / failed key on the key pad, on the other hand it could also be a bad control board, but not likely at this point.
The F2 E1 code is an indication that the control board is not seeing a circuit from one or more of the keys on the panel.
You’ll need a complete Model number to order the correct part(s).
Good Luck,
Joe / APP Team said:
Captn Tom,
Same problem for me. We have a Kitchen Aide stove, model KGRS807SWH00
Can someone provide a part number for the keypad? We’ve replaced the control board and now have this error.
[SIZE="3"]GroundControl[/SIZE]
Below are your parts
http://www.appliancepartspros.com/parts-for-whirlpool-kgrs807swh00.html
The keypad is item 2 in section 08.
Click on it’s picture for more info and a Q&A section.
The error is an open keypad erro so it could also be the ribbon cable.
