Great information on this site - but I’m unable to find solution… help:
A few days ago the refrigerator/FF side of my unit rose to 60 degrees and has stayed there. The freezer section is running as cold as always.
I have done the following so far:
Removed nearly all items from unit to avoid blocking vents
evaporator fan: running, no damage or visible wear
compressor fan: running, no damage or visible wear
compressor humming, fairly hot to touch
underside of unit / coils - clean of any debris
back of freezer NO frost - all clean
both doors seal well when closed
lights turn off when pressing the door switches
cold air flowing up from evaporator fan, through channel on back of freezer to top where opening is to Damper/FF side - just doesn’t seem to go through to the other side.
The Damper does not seem to be moving, so I opened it manually and it remains open now FULL.
There is NO airflow coming into the refrigerator side from the freezer through the opening at the Damper. I checked with Freezer open/closed it made no difference.
The air vent midway down the left panel of the refrigerator has no visible blockage. I removed the louvers and see nothing in the cavity. I am not sure where this cavity leads - or how to test the flow through that channel.
The small vent on lower left panel of refrigerator side has some cold air coming through when the slide is full open.
While running the unit with both doors open (in 70 degree garage) I can hear the compressor start (and the lights dim momentarily) - then shuts off within 10 seconds. After about a minute, it tries again… repeats.
I have both temperature controls set to the middle "5" spot.
You either have a bad compressor, or a failed start device.First, make a diagram where the wires go on the start device, then Pull off the start device on the side of the compressor, if it rattles when you shake it, it’s bad. Part #AP3873993
Relay does not rattle
Overload (black/white) rattles a little, and is in tact
Checked continuity on three compressor terminals, no short between terminals and ground.
Also - if it was the compressor/relay/overload - would the freezer still work normally like it is?
You said at the end of your msg. it was hard starting. Was that temporary? If so, just remove the freezer back panel and defrost the coils with a hair dryer if the coils are totally frosted over. Most probable problem is a blown defrost thermostat, just look at it. if bulged, it’s bad.
That only seems to occur when the doors are open, and it has had time to get really warm (due to ambient air in garage). Once the doors are closed and the freezer freezes again, the compressor doesn’t cycle like that.
No visible frost anywhere. As noted in my original post, I removed the freezer back panel and the coils in there were shiny metal, no frost. The fan is running (always) in there also. The compressor fan is running also.
I was starting to think thermister/temp controls for the refrigerator side - BUT - since i have the Damper manually opened full and still no cold air coming into fresh food side - could it still be thermister/temp control? If evaporator fan is running - what could the temp controls change?
If the compressor is running/vibrating, the freezer coils should completely frosted over with a light frost. At this time, measure the freezer temperature and post.
Freezer temperature way too cold, suspect a defrost issue, although it might be intermittant. When the freezer is -20, remove the back freezer panel and check frost pattern.
I removed the back panel, and the freezer coils are covered evenly with a light white frost. This really makes no sense… sooo cold in freezer, but no air to Fridge. Still have the Damper removed completely and no air coming through.
