I have a 1991 (model year) Kenmore 21’’ refrigerator that has just started to not cool properly.
The freezer is cold - but does not freeze the contents. The refrigerator section below, seems to stay cool, but I can’t get it to go below 55 degrees. I’ve throughly vacuumed the condenser coils underneath, set the thermostat inside the fridge on a cooler setting, and it still doesn’t get any cooler.
First determine if the compressor is running all the time.
You can usually hear it, also you should be able to feel it vibrating and it should be warm.
Check that the condenser/compressor fan is running whenever the compressor is running.
Check that the evaporator/freezer fan is running.
If compressor cycles it may be a thermostat problem.
If all the above are running then remove the cover inside the freezer so you can inspect the evaporator coils.
If partially frosted you may have a sealed system problem.
If iced/frosted over to the point where the fan cannot pull air through them you have a defrost problem.
Thanks for the reply, denman.
Yes, I believe the compressor is running. Constantly, actually. There is indeed a very slight vibration when you place your hand against the side of the fridge.
How do I check those fans you mentioned? I’m not sure where to look to see if they are indeed working.
Yes, both fans are running. The compressor appears to be running for long periods, pretty much as it always has. I turned up both thermostats (the one for the freezer and the fridge) to their max settings, and the temp in the freezer is staying at 28 degrees, while the fridge seems to hover around 55 to 60 degrees.
Were the condenser coils under the unit by the compressor and the vents front (kick plate) and rear clean?
"appears to be running" is not good enough, you have to be sure.
If the compressor is cycling on/off but the freezer does not reach set point temperature then the thermostat could be the problem. The unit thinks it has reached the set point but in reality has not.
I would also check that the doors seal are OK. Unit does reach set point but quickly rises again due to air leakage.
But if the compressor is running all the time then the unit is trying to reach set point but cannot for some reason. This can be a sealed system problem or a defrost problem.
Note: the compressor and fans will shut off during a defrost cycle. I could not find a spec on your timer but usually this is every 8 hours or so for approximately half an hour.
It is the freezer temperature that counts here as the fresh food gets all it’s cooling from the freezer. The freezer should be 0 to 5 degrees F.
It may take it 24 hours to get down to that temperature.
Yes, the condenser coils are clean - in fact, I thoroughly vacuumed them, using a small diameter tube I configured onto my vacuum to allow me to really get in and under there to clean.
The fans are indeed running properly.
Your comment about a sealed system problem intrigues me. I (assume you are referring to the freon?). My worry there is, is it cost-effective to get that compressor/freon unit professionally serviced, or will I be throwing good money at a 21 year old problem. Don’t get me wrong, in many ways older appliances seem to be better constructed than newer ones, and if that’s the case here, I’d much rather put some money into fixing this one than going out and buying a new version of the same thing.
If it is a defrost problem, what can I focus on to see if that is it? That sounds very inexpensive to repair!
I sat those lower temps early, last night, so they have had reasonable time to get where they need to be. The freezer is 28 degrees, and the fridge is 55 degrees. Does that tell us anything?
The freezer temperature tells us that it is not getting cold enough but everything depends on the why.
A sealed system or a defrost problem will cause the compressor to run all the time that is why it is very important to determine this.
Especially when a sealed system usually means replacing the fridge.
A sealed system problem requires a pro and is an expensive repair so it usually makes more sense to put those dollars towards a new unit.
If the compressor is running all the time, remove the cover from inside the freezer so you can inspect the evaporator coils.
If they only have frost in one area (usually where the freon enters the coils) then you probably have a sealed system problem. Be sure that the compressor has run for at least a couple hours. If you do this test shortly after a defrost cycle you will come up with the wrong diagnosis.
If they are iced/frosted over to the point where the evaporator fan cannot pull air through them then you have a defrost problem.
I pulled the back cover in the freezer section this evening, and there was a VERY heavy frosting/icing on the bottom half of the coils. There was also some frosting/ice on the outside of the cover that required chipping away before I could remove the shield.
You stated earlier that frosted coils indicates a sealed-system problem. Does that refer to the freon system, and if so, is that something only a professional can accomplish, and more importantly, is it expensive?
If the freon enter the coils at the bottom then it could be a low freon problem. What is happening is that the amount of freon in the sealed system gets sued up before it can cool the entire coil.
Partially frosted coils can be a sealed system problem.
Yes the freon is part of the sealed system. Low freon means there is a leak somewhere in the system.
Only a pro can fix this also there is no guarantee that they can find the leak and yes it is expensive. Often it makes more sense to put the dollars towards a new unit.
That is why it is so important to diagnose it correctly.
I would force a defrost cycle to get rid of all the frost/ice. The defrost timer is in the control console. There is usually a hole in the console to let you turn the timer cam with a screw driver forcing a defrost cycle. When the compressor and fans shut off then you are in defrost. Put the cover back temporarily so it defrosts correctly. Before doing this you may want to check that the defrost heater does come on. Be careful that you do not burn your fingers.
Let it run the defrost then turn the unit off and check that the coils are clear.
Put the cover back and let the unit run.
I would then check it every hour or so to see if the coils frost up evenly or not.
After some thought, based on what you stated, and calling a (local) tech who specializes in sealed-systems, I believe we will shut 'er down and get a new one.
This is a 21 year old unit, and while I can get it sealed and recharged for around $360.00 ($80 for the R-12 freon, $80 for the sealer, and $200 for the service call) I would still have to be concerned about the actual compressor going out, or a fan (or two), or even a thermostat right around the corner, given the age and all.
Anyway, looks like it would be better money spent on a new unit, while minimizing any probable problems on down the road (at least for the immediate future).
