Compressor and fans not working
I have a problem with a Kitchenaid refrigerator. The fans and compressor do not come on (including the interior fan). The lights work and the water dispenser tries to work (disconnected from water source). I replaced the relay and starter, still not working. Can’t find a wiring diagram.
Any ideas?
Its either in defrost or the thermostat is bad, Turn the timer and see if it starts, If not, check the thermostat.:slight_smile:
Thanks - looks like the defrost circuit board has a blown relay. Just replace the circuit board? What would cause it to blow?
