Does anyone know an approximate cost to install a new compressor for this maytag refrigerator? The parts are covered under the warranty so it is just the labor. -thanks
Labor charge will depend a lot on what area you live in.
Ceramic cooktop has two ceramic plug in units - one on the right, with front and rear heating elements, and one on the left with front and rear heating elements. When left rear switch is turned on, both front and rear left side elements are activated. Acts like the "grill element shunt" is being activated, turning on both elements as if the grill (instead of the two burner ceramic cooktop) was plugged in. Never have owned the "grille" accessory. Problem only occurs on left side of unit. Question: Anyone had similar problem before? What activates this shunt, is it replaceable, and how can I access it for service. THANKS in advance for the help!
Fred
