Hi,
I have researched this site and performed any tests that seemed relevant to my model.
I went overseas for 1.5 years and food was left in the unit while being unplugged.
In the process of cleaning, I damaged (moisture/water) the Control Box (W10175589), so I replaced it from your site. [This part includes the Electronic control (2307037)].
Unit passes all the diagnostic tests except the last one that tests the evaporator fan relay.
The condenser and evaporator fans stay on constantly.
I did this test for the Main Control Board suggested for a similar Model by "Gene":
It passed.
I also did the Compressor test that Gene provided a link to, and it passed.
The compressor seems to be functioning, and I can hear trickling noises of refrigerant coming from the Evaporator coils located inside the freezer.
The compressor sounds very quiet, and does not get hot at all, but I can hear it start and run when I am sitting next to it.
Again, both fans and compressor run constantly, but no heat.
Any ideas?
Can the compressor run, but just not at a high enough power level to cool?
I have a very large hammer and a dull axe, thinking I should create my own testing procedure!
Thanks for any feedback, Mark
