Condenser Fan not working properly
I have a side by side Whirlpool Gold refrigerator. Over the last couple days, we noticed that the middle piece between the freezer and fridge was getting hot. But the fridge and freezer were still functioning. I did some research and found it’s like dirty condenser coils.
I cleaned them as best I could, but no change. Then I realized that the fan that usually blows warm air out out from the bottom was not operating. But the compressor was still working (and was VERY hot). I unplugged the fridge and let the compressor cool down for a couple hours (assuming the fan was dead and it needed replacing).
But then I decided to plug it back in for a few hours (didn’t want everything to melt). And when I did, I saw that the condenser fan kicked on for a few seconds, then stopped.
Does this mean that the fan is still functional and it may be problem with the control board? How easy/hard is that to replace myself?
Oh also…whether or not I attempt this myself, should I leave the fridge unplugged while I wait the part/repairman to arrive? Or can I continue to plug it in for a few hours, then unplug it for a while to let the compressor cool down? (I don’t have a regular fan that I can use. Though I may just go buy one if that would help.)
Thanks!
You can buy a cheap fan at Wall Mart, just cool the compressor down with it.
Most probably a bad condenser fan motor AP4318657 If the motor has 115 volts printed on it, you can allways rig a cord for it and plug it in the wall outlet to confirm, or verify it’s getting 115 volts to it.
Ok, so interesting development. I was getting ready to pull out the fan to test it, but when I went behind the fridge, the fan was working again.
And it kept working for a few hours. But I just checked on it again, and it had stopped. I bought a floor fan which is keeping the compressor from overheating.
But what should I try? Does this sound like a bad motor or a bad control board? What is the best way to find out?
I have a multimeter, but am not sure of the best way to test the fan. Any advice would be greatly appreciated!
If you get 115 volts to it, replace the fan motor. These are difficult to test, only applying 115 volts will determine status.
Ok, I got back there and yes, when the compressor is running, the fan is getting 115V.
My concern is that I saw the fan work, and then not work. So I may have just tested the voltage during one of the times that it worked. I suppose I just have to replace the fan and go from there.
~Sigh~
I just hope this doesn’t become a long line of buying lots of parts in order to find out I only needed to buy one thing.
Usually the condenser motor gets voltage when the compressor gets voltage. Compressor didn’t stop, so it must be a bad condenser motor.
Ah, ok good to know. Thanks! Well the new condenser fan kit should be arriving tomorrow so I’ll find out for sure then.
Well, that didn’t do it. It turns out that 115V does not go to the fan every time the compressor runs.
So what should I try next…inverter box or control board?
The power to the compressor comes from the inverter board and that board probably has the condenser motor driver, replace the inverter board next to the compressor AP4411082
The board you mention is the inverter board? Is that [AP4308835](http://www.appliancepartspros.com/Appliance-Parts/whirlpool-cntrl-elec-item-number-ap4411082.aspx"]AP4411082[/URL] or [URL="http://www.appliancepartspros.com/Appliance-Parts/whirlpool-invrtr-box-item-number-ap4308835.aspx)?
BTW, thanks for all your help!
The board encased in the gray plastic box is the inverter board AP4308835
I am going by the condenser motor driver voltage failure and assume it is in the inverter board. Pull the schematic out and verify the condenser wires go to the inverter board, that would confirm it.
I ended up just replacing the control board, AP4411082. And so far so good!
Glad you got it fixed.
