if the cancel button doesn’t work or light does this indicate a problem with the board and if i have an ohm meter can and where can i test to answer this question. or is there a self diagnostic on the unit
Hi.
Most likely it is the control panel 8531254
Use the tech sheet (behind the toe panel) to run the continuity test of the touch pad.
Test the flex ribbon connector. It is available as separate part
Here are the breakdown diagrams and http://www.appliancepartspros.com/control-panel-parts-for-whirlpool-kuds01dlbl2.html
Post the results.
Simon.
I tested the continuity of the flex ribbon and no problem. ran the rinse only cycle and the first time it filled and drained the second time it failed to drain the water. Next step?
