Our display quit working; however all else still worked you could set the oven temp and it would beep when temp reached. (This seems to be a common problem as it showed on earlier posts. They however, had different issues than ours.)
Have lived without display for a year but then decided to fix it and that is when the trouble got worse. We ordered a new control panel. After hooking up, no display at all. Finally, display came on but certain buttons (4,5,6,7,8,9) would not work which go to ribbon positions 2 and 3. Did receive a PF code. Display was coming and going, found a white cable was lose, fixed that. Now receiving code F2-E1, previously mentioned buttons still aren’t working…think that all other buttons are working at this time.
