Hi,
I had the hot water hose break on my Whirlpool Duet HT washer.
I thought,I can use just the cold water hose at a cold water setting until I got the new hose.
Instead the control panel locked up .I called Whirlpool and they said unplug the unit for 15-20 minutes.It should reset itself back to factory settings.
I waited an hr just to be sure & the red light to the panel still reads locked.
I tried pressing the cancel button 2 times.Ive tried starting a new cycle.
It just stays in the locked position.
Did I break my machine ???
I really could use some advice !!!
Thank you ,
Lisa
What you need to replace is the microcomputer control. If you unplug the washer and take the three screws out in the back of the washer to remove the top, the microcomputer will be up top in the middle in the back, with all the wires going to it. It is an easy replacement. You can easily do it. The part # is 8182697. Tom
So you are saying to me the door is still locked and you can’t get it to do nothing. If so, replace the microcomputer. Tom
Following is probably an info overload but should let you run some tests.
If useless now may come in handy in the future.
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GHW9400PL2
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182677.pdf
And a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Note the above is for a 9100 so yours will have some differences.
