cONTROL PANEL LOCKED
HELP-THE control panel locked on my Whirlpool Duet HT-How do I unlock it.
See if unplugging the machine and leaving it sit for a short while will free things up. Then look inside the top for the tech notes which should show you how to put the machine into test/diagnosis mode so you can see if there is still a problem.
Te following may help
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208181790.pdf
Note always a good idea to use the actual sheets that came with the unit as there may be some variations.
Inside the top should have been a copy of the tech sheet, the same or similar to the one Denman referenced.
Here is a service manual for an earlier version of your machine which should give you additional information. Check to see if you have power getting to the control board, and if so and you cannot get the machine into test mode you may have to replace it on speculation that replacement will solve the problem.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Here is the operators manual as it sounds like yoy do not have one.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182042.pdf
Great, thanks for the update.
thanks for the info. the press "end of cycle" worked for me this time.:slight_smile:
