Control Panel Is Stuck On Lock
help, my control panel is stuck on lock. tried turning off the power but nothing is working
Under the top you should find some tech notes that will show you how to put the machine in test/diagnostic mode, but if the control will not go into that mode because it is totally locked you will have to replace the electronic control and see if that fixes things.
thanks for the tip, however i got the control unlocked. hold the end cycle button down for 3 seconds did the trick. thank you
