control pad and oven not working
my oven is not heating but the broiler is and the control pad stays on with the clock for a minute then goes off. i have ordered three baking elements and it still doesn’t heat ,what do u think could b the problem.
Hi,
If the oven is not heating I would check the simple things first.
First thing I would check is the bake element with my ohm meter for continuity.
I would disconnect the power from the oven and remove the bake element to check it.
