control panel black
My control panel was black this morning, and does not respond. Do I need a new control panel? The burners still work. I tried unplugging the range and plugging it back in.
Here are your parts, it does include a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=cre8600cce
Does the interior light work if not could be you have lost neutral.
Note lights and control board require 120 volts.
Turn the breaker for the stove off/on slowly a couple times.
If possible measure the voltage at the plug.
L1 to L2 : 240 volts
L1 to Neutral and L2 to Neutral : 120 volts
It is not uncommon to loose neutral without actually tripping the breaker.
