I have a Kitchen Aid dishwasher, KUDP01FL, and a while ago the control panel locked up on me. I tried the various code sequences to reset it, and finally got some results after unplugging it for a while and then plugging it back it. However, the ‘normal’ wash button doesn’t work, but the heavy duty and light cycle buttons do. Unfortunately, the heavy duty cycle takes forever (2-3 hours) and the light cycle doesn’t always get the dishes clean. Am I looking at replacing the control panel, or is something else involved here? I am relatively handy, is this a do-it-yourself job? Or should I just consider replacing the dishwasher?
Could be the control panel or control board.
Since unplugging it got it running it is more likely to be the control board.
The usual way to troubleshoot is to check the output from the control panel and if it is OK then replace the control board. Still a bit of a crap shoot but your odds are better.
Do you have the unit’s tech sheet (often taped to the back of the kick plate). You need it to get the panel’s outputs.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
Just ran through all the things suggested, but to no avail. Cable looks fine, no corrosion, everything cleaned and reassembled (not very complicated!). Every button works except the ‘normal’ wash button. How would I check the output from the control panel?
BTW, full model number is KUDP01FLSS3.
If this doesn’t work, then I guess I try the control panel first, and then the control board, or the other way around? Trying to do this piecemeal so I don’t have to pay for something that I don’t need. Please advise.
It has the procedure on how to check the Normal button (switch).
If it checks out OK then I would replace the control board.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Borrowed my Dad’s meter (AT&T, has to be at least 50 years old, but still works!), and was able to get resistance only if I pushed the switch in at an angle. All other switches worke fine. Got it to start by using a small screwdriver to push the side of the switch once I re-installed the panel, and quickly inserted two screws and closed the door. Shazam, it started and it going through its cycles right now. So, I will start with a new control panel and go from there. Thanks for your help!
Sounds OK to me
The tech sheet does give some cycle time info.
Also it depends a lot on your water temperature.
The recommended is 120 degrees F minimum.
Cycles will be longer if it takes the unit extra time to heat the water up.
I have the dishwasher GE GLDT696TSS model about 5 years old.
The normal light selection was dead.
The control panel delay time automatically run forever from 00 to 24 when I turn on the power, so I can’t set mode and it can’t run.
I have to cut off the power to the dishwasher for a minute then turn on. The delay time stop then I set a mode ( normal function is okay but no light up) then it can run.
I see you have the same issue and I would like to learn from you.
What part did you replace?
Does it work fine after that?
Your help and recommendation are much appreciated.
