We have a kitchenaid freestanding range that is having a problem with the display. The light goes out and when bumped re-lights for a while. All the controls still responded until a few days ago. When the oven is started (after temp is set) we get a set of beeps that indicate error(three). When the start button is pushed again the oven starts but at a lower temperature than set. I am assuming the problem is in the control board and I will replace same. The parts explosion in the catalog shows a power board along with the control board. I cannot find this board in the range and I am hoping that the parts diagram is generic and my model does not contain a power board and its functions are provided by the control board. Any light on this pain would be greatly appreciated. Thanks very very much.
Thanks. I traced the wires and that is where they go. I should have considered that first but assumed the power board was located in the control area.
Ihave contacted kitchenaid for specs that i can check before starting to replace random parts as they get pretty expensive.
Your help has been great. Thanks
— Begin quote from tommyare;496394
Tommy,
Great job,
As long as the Kitchen Aid techs get you the information, you’ll do fine.
Drop us a line when you’re done, and let us know how things went.
