control panel does nothing,oven no working
stove top works fine, clock is working. oven is not. no buttons work on panel the Off button beeps when pressed. What do you guys think?
I was wrong its older than I thought, I looked it up
Brand: KitchenAid
Type: Range/Stove/Oven
Country: USA
Model: KERI201PBL
Serial: RT0910702
This product appears to have been manufactured the week of February 27, 2006.
Here are your parts.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=keri201pbl
You seem to be missing the last digit on the model number so you will have to check the "Matching Model Numbers" panel.
See the attachment for your tech sheet.
Try removing power from the unit for a couple minutes to see if it will reset.
If this does nothing then I would say it is either the control panel or the control board.
Since you do not get an error saying there is a control panel (keypad) problem I would replace the control board first.
This is just a guess as there is no way to actually check the control panel. They do not publish the pin outs for it.
Thanks for your reply. I have unplugged the oven and waited several minutes. when i plug it back in the clock comes on and shows the same time it was before unplugged. does this tell you any thing?
