Control Panel Inoperable
The oven is no longer operable from the control panel. The screen is blank, however the clock still works.
I fear I might have to replace the control panel. Could the problem be something else though?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KEBS107DWH4
Here is a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/d1ad99f02196eae385256b3e00543ece/$FILE/SINGLEOV.PDF
The odds are high that it is the control board (microcomputer).
Since the clock works we know that the board is getting power, also a keypad fault should not blank out the display.
Try turning off power to the unit for 10 minutes or so to see if it will reset.
Thanks for the help.
