Whirlpool electric range model # GR396LXGQ2 white.
The display panel has turned off. The burners and oven are not heating. When I turn on one of the burners, the digital display comes on but the burners and oven still won’t heat. I had an appliance repair person tell me that the control panel needs replacing. I am not sure what part I need to do it myself. Can you help me accomplish this task?
Thank You,
Adi
Hi.
First of all check if there is 240VAC at the oven electrical outlet.
Post the results. Thank you.
Simon.
Sorry it took so long to get back to you. The unit is hard wired.
Hi.
Flip the breakers back and forth. then check the junction box behind the range.
Post the results.
Simon.
Simon / APP Team said:
Hi.Flip the breakers back and forth. then check the junction box behind the range.
Post the results.
Simon.
Problem solved! The breaker was bad so I replaced it and everything works now.
Thanks for your help.
Adi
Hi.
I’m glad you were able to take care of the problem.
Simon.
