Dishwasher will not start. Light will not light up when you select the wash cycle. Dishwasher does has power to it. Checked connections to all electronics on the control panel. Any ideas???
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mdb7601awq
See the attachment for the tech sheet
If you are sure that the control board is getting power and both door latch switches close then try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
If that does nothing then you will have to check the the control panel/keyboard with a meter (see the tech sheet) as it could be either the control panel or the control board.
If it checks out OK then I would replace the control board.
Still a bit of a crap shoot but your odds are better.
With an ohm meter in hand, how do you determine if the control panel or control board is bad?
See the attachment.
Your model must be the same.
