In the last few weeks the Dishwasher lights have begun to fail. Today, the panel on the front will not respond at all and start the cycle. Since most of the lights have not been working, we can’t even tell if it is reading our commands. It has been functioning even without the lights but now, nothing. It has power since the one light (Heavy Duty Wash) is still working and comes on when we select that cycle. We then push "Start" and nothing will start. I need to know what parts I might need to replace. Thanks.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDBTT60AWW
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026393.pdf
You may want to clean the connectors, see below.
Normally the way to trouble shoot the keypad and control board is to check the keypad with a meter if it checks out OK then replace the control board.
This reduces the odds of getting the wrong part but it is still a bit of a crap shoot.
Cable/Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
