I have a Maytag Legacy Series dishwasher that is about 2 1/2 years old. About two months ago one of the LED lights on the control panel started flickering, then one stopped working all together. Now, all but one of the LED lights will come on if you press the buttons, but the dishwasher will not start.
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mdbh945awb
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10111827.pdf
Your problem is a pain to troubleshoot effectively as either the control board or the keypad (panel-con) can cause this, it is a bit of a crap shoot.
In this case I would lean towards the control board as LED’s are being turned on.
I would check the keypad keys with a meter just to be sure that you do not have a stuck key (closed all the time)
I would try removing power from the unit for half an hour or so to see if it will reset.
Try running the diagnostics, though I doubt they will run.
Try the below cleaning procedure.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
