The control panel for the stove is acting up, it works sometimes, then sometimes it does not work. You push to bake it will, then it wont, its almost like it has water in it, but that is highly unlikely. I was looking at the diagram of the model and they show the wiring harness but a I see no specific reference to the control panel buttons. This hasn’t been my week, first my washing machine now this oven. I am not sure what may need replacing. Ray
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JDR8895AAW
Here is a manual. It has info on how to check the keypad.
http://appliancedigest.com/index.php?/files/file/538-16023417-jenn-air-freestanding-double-oven-dual-fuel-range-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
You said "its almost like it has water in it", is this because it feels differernt from the other keys. If yes then the keypad is probably bad.
The control board and keypad come as a set (Item 2 in Section 2).
It shows Out Of Stock which often means obsolete but call them to see if it is still available.
If the key feels the same as the others then you could check it with a meter.
You also may want to try the following by disconnecting the keypad from the control board.
Note: I am not 100% sure that this is even possible.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
